I have been fighting with my ATV carb the last few days as it was completely varnished up with what looks to be mold or something in there. The stuff is very solid and tough. It wouldn't even come off with the spray carb cleaner. I had to actually take all the jets out, float valves and other parts out and soak them in a gallon of carb soak then rub the stuff off. This being said, the atv has been sitting for about a year so some buildup i would expect. Anyway, with build up like this would a fuel additive even help or are they mostly just a preventative measure. This being asked, i do use MMO in the recommended amount so there was mmo in the gas since last year. If you do use a good carb cleaning additive, is it hard on the little rubber o-rings and stuff. That soak i have is some pretty harsh stuff. Im thinking of switching from MMO to maybe an actual carb cleaner. Also is there an additive out there that helps negate the negative effects of the ethanol that is now being added to our gas?
