So, I've been trying to diagnose my power window problem and today my brother and I tested the fusebox to see if we were getting power. We got power in 3 of the 4 columns, the dead column has the power window circuit breaker. So we thought there must be a problem getting power to that column on the fuse box. We tried to get the fusebox off but we couldn't because one screw is rounded. We then went under the hood and found the back of the fusebox and a large connector connecting to it. We unbolted the connected to look at it.
We tested between those terminals(the ones on the back of the fusebox) and the fusebox for continuity and could find it for the 3 columns but not the one with the power windows. Is it possible there's something wrong with the fusebox?
Sorry about the rabbit trail, about the car starting problem:
After putting everything back together I went to start the car. I turned the key to RUN and it beeped like usual. I then turned it over to start it and something under the hood/car made a click like sound. I think it may've been the starter trying to start but I don't know. I turned the key back when I heard the sound. A few moments later I tried it again and it didn't even make the beeped. I checked the IGN fuse and the Crank fuse and they look fine.
Did my troubleshooting for the power windows somehow cause a short in the starting system? Before I started troubleshooting the car started and drove fine. It seems like when I tried to start the car something broke a safety switch(fuse, circuit breaker, fusible link) because I don't have any power now when I turn the key to RUN but my battery is good.
Any ideas where I may have goofed to cause this? And what the actual problem is? I would really hate to have to bring this to a mechanic on a trailer.
Note: I didn't see any bear wires while diagnosing nor after. Also, I did not check every fuse, only the IGN, CRANK, and EMCB ones.
Any help would be EXTREMELY appreciated.
