Hi, I have a 15 Taurus with the 6F50 that has stalled when stopping at an off ramp. This has happened a few times, but it's only when the car is fully heated up. If it doesn't stall the RPM will dip for a second down from the 600 idle, to 350ish rpm then recover. When it stalls I can start it up right away as if nothing happened.
I took it to a transmission shop, the replaced the torque converter, valve body, and solenoid module but the issue is still present :/
