Originally Posted By: d00df00d
That unit-body cars from the same era as the hayday of body-on-frame cars were no better safety-wise.
That's not a fair comparison. Body-on-frame had been around for a LOT longer by that time.
The Mustang was unit-body. It was also conceived in 1964. I was comparing cars from the late 80's. Both were equally "developed" at that point in my opinion.
Unit-body construction began in the 1920's. It is not a "much newer" technology.
Quote:
Then why are light trucks, like the Ranger, Dakota, and the Tacoma still body-on-frame?
Longitudinal strength and cost?
Longitudinal strength at a given weight.
Quote:
Honda went that route with the Ridgeline.... and it ended up being a 4,500lb behemoth.
I thought you said and we both agreed that longitudinal strength was not a strong point of a unibody. Given that, I'd imagine they had to reinforce the heck out of it to make it carry load. From Wikipedia:
"The Honda Ridgeline uses unibody architecture ladder frame/unibody hybrid chassis. Honda claims this design gives it 2.5 times more bending rigidity and 20 times the torsional rigidity than the standard ladder frame only type of chassis construction, while retaining the load carrying capacity of the traditional ladder frame."
Exactly. In the case of longitudinal strength (which we agree on here), unit-body is NOT "stronger". Even for a given weight. It is more RIGID. Which is the point I've been making since the beginning! Rigid does NOT equal STRONG.
Quote:
The cars themselves were the least-expensive available! More expensive cars were still body-on-frame.
I just gave three reasons why those cars could still be unibody even if it were more expensive than body-on-frame.
From Wikipedia:
Originally Posted By: Wikipedia
In automobiles, it is now common to see true monocoque frames, where the structural members around the window and door frames are built by folding the skin material several times. In these situations the main concerns are spreading the load evenly, having no holes for corrosion to start, and reducing the overall workload. Compared to older techniques, in which a body is bolted to a frame, monocoque cars are
less expensive, lighter, more rigid, and can be more protective of occupants in a crash when appropriately designed.
http://en.wikipedia.org/wiki/Monocoque
Quote:
It weighs 2,500lbs more, yet is able to handle the impact into a stationary object as well if not better than the vehicle it is giving up 2,500lbs to. I cannot break it down any more basic than that.
But since a good deal of that 2,500 lbs is in the structure of the vehicle, it is making the vehicle stronger than it would be if it weighed 2,500 lbs less, isn't it?
OF COURSE IT IS! That's the point here! It needs to be stronger, it weighs 2,500lbs more! If it weighed 2,500lbs less, it wouldn't need the same structure to perform as well in the crash test.
The mass and crash performance are linked. Though somewhat indirectly. A vehicle of less mass needs less reinforcement to do well in the IIHS crash tests. A vehicle of greater mass needs more reinforcement, which is of course going to add MORE mass, so it is a catch-22 or sorts.
Quote:
You stated that body-on-frame was inferior to unit-body.
No, I didn't. I promise you.
I made two points:
1. Unibody is stronger per pound, which based on our discussions I agree should have been qualified with "except longitudinally."
2. Body-on-frame is not inherently better for occupants (which in fact
you asserted).
I agree wholeheartedly with #2. I do not agree with the use of the word "stronger" in #1, it should be "more rigid", because that is the advantage.
Quote:
The body-on-frame vehicles (trucks) that have garnered the same sort of attention to safety as their unit-body counterparts do just as well (and better if you factor in the mass of these vehicles) in the IIHS tests. Showing that either platform can be equally safe if the money is put into R&D to facilitate it.
As long as there is a mass disparity between body-on-frame and unibody vehicles, that point can't be proven by looking at crash tests.
The reason for the mass disparity is that the vast majority of body-on-frame vehicles are TRUCKS and SUV's, and the vast majority of unit-body vehicles are CARS.
What the crash tests CAN tell you is how well the vehicle is going to do against a stationary or lighter object. When you step into the "bigger than" territory, that is where the issue occurs.
