For Those Who are pro at Fixing car, You don't have to if you follow this.............
At each fuel fill
Check the engine oil level and add the proper oil if necessary.
Check the engine coolant level and add DEX-COOL® coolant mixture if necessary.
Check the windshield washer fluid level in the windshield washer tank and add the proper fluid if necessary.
At least once a month
Make sure the safety belt reminders light and all your belts, buckles, latch plates, retractors, and anchorages are working properly.
Look for any other loose or damaged safety belt system parts. If you see anything that might keep a safety belt system from doing its job, have it repaired. Have any torn or frayed safety belts replaced.
Look for any opened or broken air bag coverings, and have them repaired or replaced.
Inspect wiper blades for wear or cracking. Replace blade inserts that appear worn or damaged or that streak or miss areas of the windshield.
Silicone grease on weatherstrips will make them last longer, seal better, and not stick or squeak. Apply silicone grease with a clean cloth. During very cold, damp weather, more frequent application may be required.
Check the transaxle fluid level; add if needed.
Six Month Check-up
Inspect the front and rear suspension and steering system for damaged, loose, or missing parts, signs of wear, or lack of lubrication.
Inspect the power steering lines and hoses for proper hookup, binding, leaks, cracks, chafing, etc.
Clean and then inspect the drive axle boot seals for damage, tears, or leakage. Replace seals if necessary.
Inspect the complete exhaust system. Inspect the body near the exhaust system. Look for broken, damaged, missing, or out-of-position parts as well as open seams, holes, loose connections, or other conditions which could cause a heat buildup in the floor pan or could let exhaust fumes into the vehicle.
Inspect the hoses and have them replaced if they are cracked, swollen, or deteriorated. Inspect all pipes, fittings, and clamps; replace as needed.
Clean the outside of the radiator and air conditioning condenser. To help ensure proper operation, a pressure test of the cooling system and pressure cap is recommended at least once a year.
Inspect the throttle system for interference or binding, and for damaged or missing parts. Replace parts as needed. Replace any components that have high effort or excessive wear. Do not lubricate accelerator or cruise control cables.
Inspect brake lines and hoses for proper hookup, binding, leaks, cracks, chafing, etc. Inspect disc brake pads for wear and rotors for surface condition. Inspect other brake parts, including calipers, parking brake, etc. Check parking brake adjustment. You may need to have your brakes inspected more often if your driving habits or conditions result in frequent braking.
Annual Checkup
Lubricate the key lock cylinders with the lubricant.
Lubricate all hood hinges, hood latch assembly, secondary latch, pivots, spring anchor, release pawl, door hinges, rear compartment, glove box door, console door and any folding seat hardware. More frequent lubrication may be required when exposed to a corrosive environment.
At each fuel fill
Six Month Check-up
Annual Checkup
