4 years later Let me resurrect my own thread. AC system untouched in 4 years.
AC blowing warm air, wife said after a drive for like 15 mins the ac *might* get cold.
I put my guages on the car and it seemed a little low, 30L/150H @ ambient 85F
I added maybe 6 oz r143a. Air was blowing ice cold. Low side 40psi high side was like 240, ambient 85F (I used chart
HERE
Take my gauges off put everything away and go for a test drive. Hot air again...
I go to bed.
Next day I put the guages back on and the low side is now 115psi!
High side is really low like 50-60.
(Tiny hiss when removing little blue cap from low side port)
One thing I notice is that the auto HVAC control temp seems off. In auto mode at 85F ambient.
When set to 65 it's barely blowing, then I turn up to only 74 and the heat comes on(it was probably 95F inside the car.
How much resistance should there be when spinning the compressor by hand with car off? There seems to be a decent amount of drag when I try and spin it.
Unequal static pressure means what? Low seems much higher than high side.
I'm at a loss as to what the problem might be.
