Capri 90 Tooth Extra Long Locking Flex Head Ratchet Set
I literally just went into Harbor Freight and tried out the Pittsburgh Swivel Head. Not that smooth at all.
No it's kind of a retro (coarse) mechanism and a little less smooth at first. These ratchets will never have the minimal back drag of the newer 90+ tooth ratchets, but if you put it in a drill to "exercise" it, it will reduce the back drag.
The swivel head appears to be sealed so I have not tried to open it, but if the Pittsburghs are like other ratchets (vintage Craftsman, SK, Snapon) they would benefit from additional lube. Maybe soaking in ATF would help?
Those Pittsburgh swivel heads are high back drag. I have one that's in the giveaway pile.
I don't think I would call them high back drag but they certainly are not low!
Now that I've been using mine a lot (mostly 1/4 and 3/8, I dont use 1/2 often except with breaker bars) over the past 5ish years the back drag is about the same as it was for the snap on swivels they replaced. These were not new snapons so maybe the newer designes have imoroved; at least they should have, given the premium price!
If you want my stubby HF, message me. Just cover shipping...
