Why not just change them yourself and then take it in for the alignment? Is there anything easier to do on a vehicle than change shocks?
You overestimate me!
Give yourself some credit. Watch a couple youtube videos and get the proper tools and it is just a matter of attitude after that. I have faith that if you can do an oil change you can also do this.You overestimate me!
Ok...it's not ability...simply desire.Give yourself some credit. Watch a couple youtube videos and get the proper tools and it is just a matter of attitude after that. I have faith that if you can do an oil change you can also do this.
I see both sides of the issue at my shop. If its a typical lowering/coilover kit, charge pipe install, bolt on exhaust, i dont really have an issue installing as we long as theyre OK with the price and sign off on any liability or warranty from supplying their own junk. Usually theyre pretty generous with the times and if youre efficient and know whats going on, you can bang them out pretty quick. Your eBay brakes are squealing that we just put in a few weeks ago? 1.5 hours to clean and lubricate the pads, sorry no warranty. We are actually in the process of installing a Brembo brake kit on an 08 M3 right now. Guy calls for a quote, I have everything whats the price with a flush? He agrees and comes in. He failed to mention that its a used Brembo kit, and of course its the biggest option, so we need to cut the backing plates on the rear and remove them on the front to make work. We call back for more time and to let him know these are permanent changes and he starts complaining. Theres 6 different options for this brake setup, and his is the most involved. I told him he needs to be more clear with what he has and do his homework as well so he knows whats going on. If he had said I have the XXX mm setup, I would have quoted him the extra time right off the bat, as the smaller setups can be plug and play, pretty much a standard remove the caliper brake job. Its funny to me as a shop owner when people will spend 1500-2500 on a USED brake setup but then complain when its 100$ more for our time to install. Oh, and the pads were below 40% and the rotors had a lip already, so were going to see him again soon for a pad and rotor change. Makes no sense.
Trust me...I get it but the truck is a 2020 with 6K miles. I had all the parts still in the original boxes which were in the back seat. I expected at least they'd come out and take a look - see some brand they've never heard of or clearly they were used and ok sorry I'll pass. If they were unfamiliar with these Bilsteins (both the 6112 and 5160 are super popular) then 2 mins on the internet and they'd find out they are simple bolt-on replacements. Anyway, found a guy so I'm happy.
Roll up your sleeves and get to work.I have a 2020 Toyota Tundra and purchased Bilstein 6112 @ +1.9" preassembled and Bilstein 5160's @ stock height from Boss OffRoad - they had a great sale. I'm simply looking for someone to take out the OEM, install the Bilsteins (which are still in their boxes) and perform an alignment. This doesn't require any lift kit or shackles and they simply bolt right into place.
Shop 1 is a busy shop with a great reputation - they've done work for me before. "Sorry, we don't do upgrades". Ok...
Shop 2 was recommended by a friend and it has 8 bays without a single vehicle in any one of them at 10am on a Tuedsay. "Sorry, we don't install customer provided parts. It's just not worth it for me". I explained they are brand new, still in boxes and that I'm not asking for him to guarantee the shocks beyond it being installed correctly and if I have a problem with the shocks I'll call Boss Offroad. "Sorry".
Shop 3 I was just passing on the way home. It has 6 work bays with one car in it. "Sorry, I'm going to pass".
I get there is some liability in installing customer provided parts but these are still in the box and purchased from a reputable online company. It just seems to me for places that don't seem all that busy it would be an easy couple hours and an alignment - hell overcharge me what you were missing out on the sale of the parts. Just sort of ranting...I didn't think this would be such a big deal.
I just attempted to confirm the referenced shocks would fit the truck listed, and while it only took me 3:30 seconds to find an answer, it wasn’t the answer I’d hoped for.
- one of the referenced shocks couldn’t be found as a suitable replacement.
- the other did show to be a suitable replacement but in suspensions raised higher than stock ride height.
If I were a shop owner, I would likely turn down the job as well. Too many unknowns that would require time to figure out; time I couldn’t bill for either.
It wouldn’t be anything personal, it’s just not an economically attractive job I would want to take on, that’s all.
I can understand shop reluctance to do this job. Those shocks take parts from original to complete the set. I understand you have 6k but none the less they have to take your original struts apart and swap out factory with aftermarket. Then they have to set ride height, spring load as well as an alignment.
I was told years ago missing parts are potential issue. I could do it but pay for labor even if not installed.
Not according to their site. They claimed direct bolt on but you have to use bumper and shock mountThat's the thing...front coil-overs are preassembled at desired ride height. No setting ride height, no setting spring load. Literally, it's like 7 bolts per wheel and an alignment.
