When I was living in the tropics, I exclusively use water for my toyota 4AFE engine. Acquired the car at 78k km on the odo and the previous owner replaced the radiator with a brass top one. So I decided to check on the thermostat as most radiator shops there always removed the thermostat when fixing the radiator. And lo and behold, when I drained the radiator to work and open the thermostat housing, it just pure water and no coolant/antifreeze. And there was no thermostat in there. Put in new oem thermostat, changed the radiator to a new aftermarket replacement plastic top and bottom. But run out of budget and just decided to pour in tap water straight from a garden hose. No cooling/overheat problem until the car reached 170k km when finally the original waterpump gave up. But I didn't overheat (luckily). Note, I changed the timing belt at 90k km without changing the original waterpump. So in my own conclusion, is coolant/antifreeze can prolong the service life of waterpump? Maybe. Is pure water bad for the cooling system? Yeah if your living in colder climates. But in the tropics, I dont think so.
