Hi all,
I did get several suggestions of oil grades for my old Volvo engine (atmo) with over 200K: 0W40, 5W40 or 10W40. I do understand the differences between these grades and the fact 0W and 5W appear "better" for cold starts and winter. However although all these oils are SAE40 when hot, they have different viscosities when cold with a 10W being thicker than a 5W and so on. Now Volvo recommends a 5W40 for that engine but that is for a NEW engine and certainly not for a 200K miles one. To my understanding it may be perhaps better to run a 10W40 (even in freezing cold Switzerland winters) rather than a 5W40 in that old engine. The main point is that I can get a high mileage oil (Valvoline Maxlife) only in 10W40 here, not 5w40.
Therefore would it be possible to figure out if a 10W40 is fine even in winter by using an oil pressure gauge??? I mean if I get a proper oil pressure on cold start, it should mean the oil grade is OK with 10W. A 5W may produce a low oil pressure when cold (not to the extent of lighting the oil light in the dashboard though...) and that would mean the oil is too thin when cold for my "worn" engine. Does this make sense?? I would move to a 5w40 grade only if it is really better but I do believe a 10W40 high mileage oil with seal conditioners may be much more beneficial to even a full synthetic 5w40. Afterall the 5w40 grade is good for new engine and perhaps no more for a 200K miles one....
Glad to get your opinion on that.
