quote:
Originally posted by kickster:
quote:
What was the pressure at 2K, 3K, etc RPM? - this is more important.
Pressure is @ 1.8 Bar (1900 rpm) 2.0 bar (2200 rpm) 2.5-3.0 Bar (3000 rpm) 3.0+ above 4000 rpm.
The pressure is high while driving. It only goes low at idle!
It is a waste to drain the brand new AMSOIL after using it for 2 days. I am thinking of removing 500ml and replacing it with 20W50. It may increase the viscosity just enough to stop the dummy light. [/QB]
You might want to try an oil thickening additive like motor honey or something, just as a stopgap measure to keep using this oil.
Obviously it is important to get the light to turn off, cos you need to know when your oil pressure is REALLY low, like when there's a leak or a spun bearing or whatever.
Another option would be to drain it and save it. Refill with something thicker, then for the next OC make up whatever didn't come out (like what's left in the filter) with something really thick like a 20-50 like you said, then after that use a 10-40 or whatever.
I would also like to clarify if it's the oil presuure while hot that is the problem. If that's the case maybe you should try a 5w50 oil so you don't sacrifice as much of the low-temp flow characteristics as fwith going to a 10w oil.
