I have an infiniti g35 coupe with the vq35 engine.
the manual specifies 5w30 is preferred but 10w30 and 10w40 can be used if the temp is greater than 0f. where i live (central texas), this means 10w40 is fine year round.
here is my question, since 5w30 is fine and 10w40 is fine imply that 5w40 is fine as well?
do you consider the vq35 to be a high rev engine (seems to basically always run around 2700 rpm during normal highway driving)?
what grade oil would you run in this engine for temps that pretty much average 80s to low 100s year round?
