I thought the real answer is "the lube oil is the most valuable part"Good to know. He mentioned something like “you already broke some chains of petroleum down; so doing more is more complex”. I wanted a real answer not his bs one
Yeah I would run at least 10% used oil in Detroit's before they would burn and leak oil faster than it would accumulate in the crank case. Then it was just a matter of cutting back the oil to maintain the right level.I doubt that led to demise of the engine in skidder
I will say no, I can remember there was an oil here that was talked about 4 awhile, that was made from recycled oil, and via a VOA it looked terrible. The oil name was maybe Next Gen or something.Good Morning folks. Can we do more like make gasoline from rerefined/reclaimed and recycled oils? I know lot of it gets burned for heat and fuel. Didn’t know if anything has changed or no.
Thank You
The problem with that is draining it and keeping it uncontaminated.I know many will scoff but the Mobil 2 concept still works perfectly fine in a beater. A quality synthetic drained out after 5000 miles still has servicible life left. Will easily go another 5000 in a beater. Just sayin'.
Several schemes to re-refine used PMCO. The most promising was BP feeding into a Coker along with the normal Coker feed. After inspection during the next turnaround it was found processing the used PMCO took significant equipment life, far more so than the normal Coker feed.
The additives that transform a base oil into a finished lubricant poses real challenge to re-refine used motor oil.
Safety Kleen has several used oil re-refineries around the USA. Their approach uses some equipment not used in refineries that process crude oil, a thin film evaporator in addition to equipment used in a crude oil refinery (distillation towers, a hydrotreating reactor) and produces three grades of base oils.
This web page has more details on their processes, including recycling used motor oil filters. I take my used oil and oil filters to O'Reilly. O'Reilly is the only collecter of used oil that also accept used oil filters for recycling in my are.
https://www.safety-kleen.com/services
This video has a simplified overview of how their oil re-refing process is configured.
Yes, that preference for government agencies to preferentially use re-refined motor oils has been true for some time.The US government still appears to be buying that re-refined motor oil.
For oil filters I burn them and recycle what doesn't burn.
Safety Kleen oils have served my works vehicles well.Yes, that preference for government agencies to preferentially use re-refined motor oils has been true for some time.
A few years back Valvoline offered at retail motor oil formulated from re-refined base oil products called Next-gen. This only lasted a short time in the retail space, likely because it was more highly priced than comparable Valvoline products formulated with base oil from crude oil.
Without the government agencies preferentially using re-refined motor oil, it would be a small niche market that Valvoline found too little demand in the retail market to be sustainable.
Good Korning sir. I believe you mentioned that natural gas prices trend with used oil or vice cersa. Do they get other gases like propane, benzine etc out of used oil?I’m not sure who told you that about Valvoline. But you’re not correct about any of it.
Also, the re-refined base oil business is booming. There are tons of products out there that use re-refined base oils.
Source: Kinda used to own the re-refinery that Valvoline bought its base oil from. I even hauled it to them, on my trucks. And they even used my PCMO formulations.
Yeah it didn't last very long and I found it odd that it wasn't the cheapest oil on the shelf.Yes, that preference for government agencies to preferentially use re-refined motor oils has been true for some time.
I have maybe 2 5quarts of their nextgen maxlife 10w30. Got it with mail in rebateYeah it didn't last very long and I found it odd that it wasn't the cheapest oil on the shelf.
They still make it?I have maybe 2 5quarts of their nextgen maxlife 10w30. Got it with mail in rebate
Exactly, They now have a process where they can burn whole scrap tires without the need for shredding. At 1800 degrees F there is not going to be anything left.this was an interesting read. There is a tire processing plant not far from my family ranch that "processes" tires, maybe this is what they are up to for another company I've been watching which has stirred up the local community quite a bit for their plans on "yet another" concrete/limestone plant.
https://www.sciencedirect.com/science/article/pii/S1026918520300172
Does the fire stink of burned oil?I soak fire wood in used oil and burn them.
Many folks use 5,000 miles as an OCI. That used oil is still good for at least another 5,000 miles in a beater.It wasn't that hard when I did it before. Wipe down drain pan, drain oil, pour into empty oil jug from previous change using a clean funnel. I even once tried using a paper filter just to see what it would catch, but nothing of significance was filtered out.
Key word here is "using it in a beater". If you can't hurt it, you can't hurt it. Its an eco friendly action too.
No, I got it when it came out at Autozone and advance AutoThey still make it?
