JHZR2
Staff member
Originally Posted By: George7941
I am going to disagree with the replies so far.
The "value" of a battery is directly related to its weight. The more it weighs, the more it costs to make and you are getting more for your money.
With the weight kept constant(let us say, 40 lbs), CCA and Reserve Capacity are in inverse relation to each other i.e. the more the CCA, the less the RC. So do not evaluate a battery on CCA alone.
A lot of CCA means thinner plates and while this is good for cranking on a cold winter morning, it could lead to shorter battery life.
When I am looking at batteries, I place more importance on RC.
Excellent post. Very good description.
For the OP, the battery will provide only enough current to match the load resistance. Remember, I = V/R. V is fixed or varies just a bit, say 10-12V, so you get what you get current flow-wise. Power is just I x V.
So a battery with lower source impedance will provide more power with less drop. The ability to provide power can vary greatly, the actual voltage drop will not. The load impedance is fixed.
The only bad thing with having higher cca is that if you have a hard short without protection up to the point of the fault, you'll overheat the wires and start a fire with much higher likelihood as you can source more power.
I agree that I'd prefer RC over CCA, assuming I have enough CCA for my application. So long as a short isn't formed, the higher RC battery will be able to undergo more degradation before failure.
