I can't justify buying a Mityvac just for oil changes, but if it also works for bleeding brakes then maybe it would be worth it. I have seen brake bleeders before that use pressure to force fluid through. It seems like the principle is the same...hook it up to a caliper with some sort of adapter, crack the bleed valve and suck the fluid through...but I don't know if that's different than forcing fluid through with pressure.
