Quote:
Look here and scroll down near the bottom. It describes how to get to the neodymium magnets in an old HD. It takes a little work.
Quote:
Quote:
Rare earth magnets are amazingly strong. I've attached a disc shaped one to the exterior bottom of my oil filter, thinking at least some of the magnetic force would pass through the filter and perhaps catch and hold iron-based particulates.
Has anyone had any success with this concept? Further, has anyone droped their oil pan and inserted a REM in the bottom for the same purpose? I would imagine you could leave one there for many thousands of miles before having to clean it. What would be the best shape of a REM for this purpose - one that lays flat in the bottom of the pan, or a cylindrical shape that sits up a bit?
Would all the magnetic engineers please chime in...
From my understanding, the smaller a particle, the less attracted it will be to a magnet and the more likely that the flow will push it along. With that in mind, only large particles that would have been otherwise caught by the oil filter will be trapped by a magnet, while the smaller ones will move right past the magnet entirely. While I am confident that particles will be caught by a magnet, I do not think that any of the ones that are caught would be ones that would have otherwise avoided filtration.
Quote:
Well, the flow goes from the outside to inside ..so it's unlikely that a particle is going to get by the magnet and then get pulled back through the media ..or so I reason.
Quote:
Yes, as Gary as stated, the oil flow is from the outside in and I have cut literally hundreds of oil filters with Neo magnets installed and certainly no damage to the filter element. The particles are pulled from the oil prior to the media. And yes, high quality Neo's pull from angstrom level to chunks and clunks, equally.. Thus greatly increasing the oil filters filtration capabilities. Caputuring the #1 wear component (iron/steel) and allowing the filter media to do its job on non ferrous better.. Basic win/win...
George Morrison, STLE CLS
Quote:
If you have very strong magnets, stay away from the top and bottom. Top could impede/block drain back device. Bottom could tip the spring over.
