T Tourist Joined Sep 22, 2005 Messages 93 Location Malaysia Jun 15, 2007 #1 Hi. The manual calls for DOT3 brake fluid in brakes system. Can I use DOT4 instead? I am assuming I could but would like some confirmation. Thanks.
S Squishy Joined Apr 5, 2007 Messages 289 Location Orillia, Ontario Jun 15, 2007 #3 Any glycol-based fluid will work in your system. That means DOT3, DOT4, and DOT5.1 (or DOT4+ in some cases). DOT5 is silicone-based and will not play nice with the existing fluid.
T Tourist Thread starter Joined Sep 22, 2005 Messages 93 Location Malaysia Jun 16, 2007 #4 The funny thing is, the brake fluid reservoir cap states "ONLY DOT3" whereas the clutch pump fluid reservoir cap states "DOT3 or 4). So the question is: Why "ONLY DOT3" on the brake fluid reservoir cap? btw, mine a Isuzu Trooper 3.1 TDi.
E ewetho Joined May 5, 2006 Messages 1,304 Location Kankakee, IL Jun 16, 2007 #5 IGNORE and use either with confidence. FORD DOT3 by the number could easily be DOT4 if they wanted to label it as such.
O onion Joined Feb 4, 2007 Messages 2,097 Location kansastan Jun 16, 2007 #6 I've been told that DOT 4 has a higher boiling point, but is more prone to absorbing moisture. It'll work fine, though.
The Critic Joined Aug 30, 2004 Messages 31,976 Location CA Jun 16, 2007 #7 Quote: I've been told that DOT 4 has a higher boiling point, but is more prone to absorbing moisture. It'll work fine, though. Click to expand... Yup, so be sure to change it at least every three years.
T Tourist Thread starter Joined Sep 22, 2005 Messages 93 Location Malaysia Jun 17, 2007 #8 "Castrol Disc Brake Fluid is a high performance synthetic brake fluid. It has excellent anti-vapour lock properties that provide extra safety." Hi. May I ask what does this "synthetic" means? Is it just a marketing hype or just plain glycol based stuff? http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=82914665&contentId=6005302
