ROFL!!quote:
Originally posted by Dan4510:
Not a good method, you might get the car pregnant!
Seriously though, the fluid that needs to be changed is that close to the brake calipers and cylinders. That fluids gets contaminated and needs to be flushed out. changing only the fluid in the master cylinder does not change it at all.
Dan
I worked in a brake shop 1990-1993. The whole time I was there, I never heard of anyone changing brake fluid or bleeding brakes when the lines had not been opened. The owner was very strong on rebuilding the wheel cylinders or calipers on every shoe or pad change. Often again they are refilled and bled, most of the old fluid is gone.quote:
Originally posted by ZmOz:
The pads were recently replaced by the former owner. I don't know very much about the brakes...is it common practic/required that a shop change the brake fluid when doing the pads? I don't have ABS BTW...
I just flushed and bleed mine last week. 96 Corvette bleeder screw measures about 0.295 to 0.300. 0.250 ID vinyl tubing is a nice fit.quote:
Originally posted by Jim Spahr:
On a GM RWD car, does anyone know what the brake bleeder size is? IOW what size tubing should I buy to fit on the brake bleeder fitting?
