Can Am Spyder
When the Spyder was first released, I went to a ride day at a local dealer in 2007. They had a couple groups on each ride. The ones that wanted to push it on something they've never ridden before and those that just wanted to cruise. Seeing as no one had ever ridden one before, I am the type that wants to follow the leader and chose the push it group.
I had a ball on that thing, it turned in a high RPM at 60 mph in top gear, but I was coming for a motorcycle that weighed less than half as much. Performance with that Rotax V-twin was more than acceptable.
Only issue I noticed, and maybe his changed over the years is unless I was extremely offset to the left of the lane or the right of the lane, the front end wanted to track the groove made by cars. It wasn't wide enough to cover both grooves and didn't like having one side in the grooves and the other side on the more or less unused pavement. It would wander, unless I maintained the noticeable offset positioning in the lane.
My wife got her three wheel endorsement as a "bucket list" 50th birthday "try something new". A Spyder may be added to the garage over the winter. She thoroughly enjoyed the safety training course to get the endorsement. For myself, I am a two wheeled rider and wouldn't choose a Spyder if it was solely me. With her in the picture, it could be a nice addition to the stable to play on once in a while.
2x, I also did the prerelease proto ride in a spirited group back then, just with the parts mgr. at that dealer. Old 990 had plenty of power and it was a hang on ride. It changed my view on regular trikes, no way with two wide in the rear for my riding ''golden years''.
My wife's 1330 has more than enough power. It will spin that big rear tire for 50 feet out of the hole with my big arse on it.
The older models with the twins were not reliable. The newer ones with the 1330 triple are. The one I rode turned a pretty low RPM in 6th gear. 60 mph was just 3K RPM. 80 MPH was right around 4K. These things can easily do highway speeds all day long...
There really is no leaning on a Spyder. Leaning into it to help stay on the machine, yes, but no leaning like on a a two wheeler. The Spyder tracks like it's on rails...
Yep, leaning to the inside while the machine stays flat was a bit odd at first, you get used to it pretty fast. It's either that or get thrown off.
The two that I rode did track through the curves very well, I was impressed. Wife and I have already discussed, when I can't hold us both up anymore, we'll be looking at a Can-Am. I think it's a much more stable platform than a conventional trike, lower to the ground for one.
The Spyder v-twin motor was reliable. The problem with them now is that parts availability is shrinking, as is service support.
That's not what Spyder owners say on the forum. They said the twins weren't reliable, but the triples are...
