Originally Posted by dareo
For whatever its worth the only time i've seen an engine fail on a 20 weight was a Toyota 4AGE 20 valve being rallied. It already had a ton of abusive miles on it and the owner liked 5w20 for winter street use, ended up taking it to a rally cross in the spring and it threw a rod. Was it the engine's time to go? Or was it the oil? This thing would rev to nearly 8,000 and was never spec'd a 20 weight.
Racing is always kind of an odd thing. I thought that supercompetetive race teams will often use thin oils for qualifying laps, but perhaps shift to a thicker oil for longer race days where the oil might be cooked after an hour of beating it up. Also - that might be the right situation for more frequent oil changes.
And of course the use of more advanced antiwear additives was mentioned. That's probably the one thing that makes thinner oils most acceptable. And why wear from cold starts isn't as bad as it used to be.
