Few questions:
2011 Camry, 4cylinder/6spd manual/base
Just got done with the 50kmile service. Front brakes have "10" indicated (mm I'm guessing) but rear is at "5" and the tech note says uneven wear and/or uneven angle (two notes, different places). Am guessing we aren't braking hard enough to overcome the brake distribution (that prevents nose dive), not sure it's worth bothering, since brakes are cheap. I think, haven't priced Camry pads out yet...
Any reason to replace rotors at the same time, or if they aren't badly rusted to leave in place? My Jetta goes through rotors faster than pads, due to rust issues; the Camry does not have warped rotors so if they are ok I'm thinking of reusing. Anything complicated in rotor removal?
Also, do the pistons have to be turned in? Standard clockwise?
What is the grease required for the sliders? I'm thinking of buying that, and pulling the wheels one of these weekends to see what is noted. I've never had to lube sliders before, but I'm guessing now is the time to start.
Seems like short brake life to me, but the wife does lots of short trips. The tire life is what bothers me; 20k on Michelin Primacy's and they are at 5/32's left (supposedly, I didn't measure).
