Greetings:
Am considering a purchase of what will be our first Subaru vehicle, and most likely the Impreza. How is the build quality in general of their automobiles? There is certainly enough of them on the road if you take the time to look! I am mostly interested in the AWD system reliability and which system available on the Impreza would be more desirable for the long term, if that is even an issue? The manual "viscous coupling" or the automatic "hydraulic" version.
I read one person's experience with having a premature tire failure and being advised to replace all 4 tires due to the possibility of the viscous coupling over heating and failing if only one was replaced. Is this a serious consideration with the manual trans option? How do the two transmissions/drive train set-ups perform in general with regards to shift quality? Can I change the fluid over in either to an Amsoil or Redline product and forget about it for 30K so to speak?
How do the Boxer engines perform and are they smooth running and mostly trouble free for the long term? Last engine that I had even close to this design was my 1973 Bug! Not sure if it is true but I may have read somewhere that the cranks were forged steel. Are there any issues with the engines that the company hasn't addressed?
Thanks for any input.
