Hey guys,
I've been putting together a winter beater ('96 Audi A4 quattro) and just have one problem to solve. I sometimes get a noise similar to loose change clanking around when going over bumps. It doesn't happen all the time, and I can only hear it with the window down at highway speeds.
Searching through some forums some have said it's possible the brake pads make this noise if no lubed correctly, or some bad swaybar endlinks.
New parts on the car:
-Pads/rotors up front (clip on pad holds in caliper piston tight)
-Steering rack (was leaking very bad)
-Caliper/carrier for caliper, pads/rotors in rear
I know the car has more of a complex suspension, but I really didn't see any bushings that look toast. Any good ideas or input would be great!
Zach
Zach
