Nope. It will be listed with all the other options on the glove compartment door.'m attaching a picture of a vehicle near me. I'd like to know if this picture depicts a z51 package or not ??
Look in the Glovebox. There should be RPO codes listed. If it has the Z51 package it will be listed. Another way is to look at the power steering pump, according to Corvette forums the Z51 included a power steering cooler.I'm attaching a picture of a vehicle near me. I'd like to know if this picture depicts a z51 package or not ?? Didn't see what I was looking for in a quick search.
Appreciate it.
Yeah, I've read about that numerous times..That adjustment knob means that the car has the selective suspension, sometimes called "magnetic" due to the magnetorheological fluid in the shock absorbers. It does not have the Z51. 5th generation corvettes from 2001 on have a different electronic brake control module than earlier models. If the stability control/ABS run by the EBCM has an issue, it can generally be repaired on 2001 and later vettes, but is almost impossible to fix on earlier models. By this time the steering lock issue that the C5's had, has almost certainly been addressed by a prior owner.
