good link - thanks.
Here's some info I found from Oillab.com. It's an Oil Analysis service, like Blackstone and Oilanalyzers.
Hope I can get it to copy/quote correctly:
"SPECTROANALYSIS
Spectroanalysis is the analysis of the metal content and additive package. This test checks 19 elements and reports them in parts per million. These numbers represent the elements less than 5 microns in size. The spectrometers design limits its detection level to 5 microns and below. To evaluate the particulate larger than 5 microns, other test methods must be implemented.
The spectroanalysis is used to look for bearing or bushing wear in the form of copper, lead, or tin. The spectroanalysis also looks at dirt levels in the form of silicon. Wear in pumps, housings, and other points of contact can be evaluated using this information. It is important to remember that these are small particulate. If there are large particles of metals in the oil, larger than 5 microns, the spectroanalysis will not detect them. The larger particulate will be detected in the particle count and or the filter analysis, if the particulate are large enough.
The additive package of the oil can be identified and evaluated using the spectroanalysis.
PARTICLE ANALYSIS
The particle count is the single most important part of the report to measure the efficiency of the system filtration. The particle count measures all particulate in the oil larger than 5 microns.
Particulate include: dirt, carbon, metals, fiber, bug parts, etc.
The particle count can be done using either laser or optical methods. The laser method reports the quantity, size and distribution of particulate, but not what they are. The optical method gives a quantity, size, distribution and identification."
In reading this, it would lead me to believe that spectroanalysis is much more telling of how well a bypass filter would work, because it's effective range is
Soooooo .....
Wear metals reported by spectral analysis would be a very good indication of how well your bypass filter is working. In fact, particle counts are more appropriate for FF filters, based upon the micron size each test is biased towards.
Soooooo ....
My results from my study would in fact be VERY accurate and telling of how well bypass filtration compares to conventional FF filtration, and how well one bypass compares to another. Not that particle counts and filter studies aren't good info (they certainly are), but according to this website, and other information from other oil analysis labs, SPECTROANALYSIS IS THE MAIN TOOL IN COUNTING THE INDICATORS OF WEAR REGARDING CONTAMINATION AND DESTRUCTIVE MATTER IN SMALL MICRON RANGES, SAY AT OR LESS THAN 5um. That being established, you cannot reasonably refute the data I've posted regarding the study.
"SPECTROANALYSIS
PARTICLE ANALYSIS
Soooooo .....
Soooooo ....
