I am looking at adding an auxiliary transmission cooler to a Ford C6 tranmissoon with a higher than factory small converter. I was looking at using one of Hayden's Thermal bypass coolers. I know the bypass works by ATF viscosity and not an actual temperature. However, does anyone know what the approximate temperature range these bypasses activate?
I am thinking of using a Hayden 699 which may be overkill, especially if driven in cool weather, but that's where think the bypass will help. I am also planning on running it in series with the factory in rad cooler. The engine runs a 180 thermostat and runs pretty near there. The trans is running too hot though due to the converter.
