- Joined
- Sep 28, 2002
- Messages
- 39,799
Okay ..this (hopefully) will be the beginning of the end of the bypass valve debate. We'll miss this point of contention that we've swatted back and forth across the net like a volleyball for as far back as I can remember in the history of the board.
Anyway ..here's some images. With 427ZO6's advice, I got, what was in his opinion, the most restrictive (or fine) media, PURE ONE's in 3 popular sizes: PL3001 (PH8A), PL14670 (PH16), and the dinky PL10241 (ST3614). 427ZO6 also found that a NAPA 1410 (Wix 51410) is a PH16 sized filter without a bypass. This will be installed at some point as well.
I decided to put the dinky one on first ..just so we can get somewhere quicker.
I then plumbed my little gauges into the passenger compartment in an easy to read area.
Sorry for not rotating the image on this one
My first observation??? I've got radical upramp in pressure with hitting the gas pedal...it swings up from the normal 30/32 idle ...all the way up to 80 psi (which I suspect is my pump's relief setting ..or around there - 82 is the highest pressure that I've observed to date).
Here's the "odd" thing (I haven't quite integrated what it means ..but then again ..I haven't dwelled upon it too long either
) .... when I blip the engine ..the DOWNSTREAM PRESSURE responds with more swing. That is, you may be sitting there with any old PSID ...but before the upstream pressure increases ...the downstream comes up to meet it. This may or may not support one of my theories ...I sure hope so
I'll start my log tomorrow. I'll try and record ambient temp. Right now I've got 10w-30 oil in there.
[ March 27, 2005, 03:04 PM: Message edited by: Gary Allan ]
