Okay,
So as I know now, Walmart is out of filters for the most part. I normally use basic filters like the Supertech or the Orange Can of Nuclear destruction.
I've started changing the oil in my my friends Subaru Forester with the 4cyl 2.5 non turbo engine. Calls for 0w20 oil which we are using now with some 5 k runs of Valvoline Restore and Protect. Maybe later we will try the ESP 0w30.
So I was looking at alternative filters since Walmart is no longer viable. When I first bought filters I looked in the filter book at Walmart and it gave the SuperTech6607 which is short, and the Fram PH7317 which is taller as the options. I bought both for the heck of it. Not thinking about bypass PSI as I figured the book was accurate (enough)LOL.
So now I'm looking at Purolator filters as an option (Good deals on Amazon at times)
On their filter lookup page I found this.
For the Forester it says the One PL14615 which is 2.93 inches tall and has a bypass psi of 20-30
When I cross referenced the SuperTech6607 which is 2.93 inches tall it gives the PL14612 with bypass of 14-18 psi.
When I cross referenced the Fram PH 7317 it gave the PL14610 3.52 inches with bypass of 14-18 psi.
So as a side note, I changed the oil in another friends Altima with the 4cyl. I looked up the filter and it said to use the SuperTech 6607 which I had on hand for the Forester. Cool!
So I asked Google AI what the bypass was for the SuperTech and it said between 8-11 psi. Remember, this is the same filter the catalog said to use on my friends Subaru.
Since the Subaru and Altima were calling for the same Walmart filter I looked at the Microgard Select because I know that is popular. The same filter came up as being the one to use for the Subaru and Altima. I could not find bypass pressure listed on website so I asked AI. It said:
MicroGard Select MSL57055
is often cross-referenced with the WIX 57055 or WIX XP 57055XP, which also utilize the 27 PSI bypass setting to meet original equipment (OE) requirements for high-pressure oil systems. Standard oil filters typically have much lower bypass settings, often between 8–15 PSI, which could lead to unfiltered oil circulating too frequently in engines designed for a 27 PSI threshold.
So this is putting the psi for the Microgard to be similar to the Purolator pl14615 for the Subaru, when for the Altima calls for a Purolator pl14610 with the 14-18 psi.
Basically I'm getting mixed psi settings for the bypass when I look at different filter recommendations from catalogs and websites.
We live in a warm climate with a cold winter morning being in 30's and a hot summer day over 100. 80's during the day for the most part.
Is the bypass psi really something I need to be concered about with my friends Subaru? It currently has the SuperTech 6607 in it.
Amazon has a great price on the 14612 right now. Under $3 for the "Tech" which list the same settings as the One 14612.
Share your thoughts please.
