The psi rating of the oil system doesn't enter into the situation. We're looking at the differential pressure between the clean side of the filter and the dirty side, a.k.a. psid, or delta p. If the oil pump is putting out 50 psi, and the outlet of the filter is 48 psi, we have 2 psid pressure drop across the filter. That's what the bypass valve is looking at.
When I spoke with a Baldwin tech rep, they said that the engine manufacturer sets several parameters for the filters, bypass differential pressure being just one.
Some filter media will allow flow more easily than the OEM media, some may be more restrictive. All this will effect the decision on the bypass setting, the filter makers know all this, and they don't readily share that info.
Ken
Ken
