Lenny,
Soot in diesel lube is not "somewhat" normal...it is totally normal.
Don't worry about it. All proper diesel lube oils, and Delvac 1 is one of the best, handle the soot with no worries for you. You're good for the full oil drain interval shown in your owner's manual. With the Delvac 1, you're probably good for twice that oil drain interval, but don't risk your warranty protection.
I've run many industrial diesel engines where the oil turns black an hour after the change. I've recently been running a locomotive engine in a generator application for about five days every two weeks, the oil (Chevron Delo 1000 SAE40) has been in that engine for over two years, the oil is black as black paint, we're using high sulfur fuel, and the lab tests on the oil are still good. Due to the large sump capacity (600 gallons), we won't change the oil until the lab says to do so. And, no bypass filter or centrifuge, only a big full flow filter (eight 3' long, 8" diameter micronic pleated paper elements in one canister).
Ken
