I've got a 1996 Chevy S10 with a 2.2L and an automatic transmission. (Same engine as the cavalier)
I am currently rebuilding the engine (bought it with a blown motor)
I am going to be building a turbo kit for it hopefully and it will have a bit of internal work done to the engine.
I do drive a decent amount. To drive to and from school, its around 70 kms per day round trip (about 45 miles) five times a week. Thats just straight to school and straight back.
I would like to have a better filtering oil system and possibly get a longer oil change interval, and more oil capacity.
I've read about the Amsoil (I like Amsoil, I run it in my sled, and my go kart) bypass filter, however it seems rather expensive.
Is there any way to do it yourself?
I've seen the remote filter kits from Summit Racing and Jegs, and what not. I've read online you can use two filters (not the remote kit that holds two filters, as the second filter isn't really used, just for oil capacity, at least thats what I read), so you have the aluminum piece that screws onto the motor, a feed line going into the remote block, through the filter, and then to the outlet. The outlet from filter one goes into the inlet of filter two, and then the outlet goes back to the aluminum piece and into the motor. This would make it run the oil through two filters.
Would this work? Would it give me longer oil change intervals? Would it kill my oil pump? (dont forget the turbo too)
I've seen the Amsoil bypass filter installed online on a 2.2 Cavalier... I just can't bear to spend that much money.
