I don't go lower than the rating and in fact am currently running 2" bigger rims and 3-speed ratings HIGHER than the car was originally intended to use...so I feel much safer thank you.
KitaCam said:The tire info was right out of the 2015 Tire Guide.
"Tire Guide" ????? If that's not a Toyota publication I would not consider that an authoritative source...and again I don't consider ANY S-rated tire "Premium" ... though a tire model may be called "Premium".
The Tire Guide is a industry guide, not Toyota. Just look up OEM tires for various models on tire rack if you don't believe me. Premium Michelin, or whatever T rated, or would you feel safer on a W rated Goodride, etc. junk tire? In 2012 Toyota went back to S rated on the LE Camry.
I'd like to see a technical definition of the term "premium" and especially how one can make a 149 mph sustained speed tire "cheap".
