Buying MIchelins from Sams or Costco
Having a micro fleet of vehicles, all on Michelins. The Michelins sit forever in the sun, and then the call comes to do a cross-country move towing a trailer loaded to the max, along with the bed of the pickup loaded to the max. Those ten-year-old plus Michelin Defenders, under huge load, on burning hot summer interstates, driving through the heat of the day, for 2,000 +/- miles, have never ever showed one sign of duress. Instead, these ten-year-old Michelin Defenders provide full confidence.
I will take a ten-year-old Michelin Defender to tow across the country in the summer heat over 95% of brand-new tires.
Pick the tire, not the date of manufacturer, and sleep well at night!
Just make sure you don’t kill some family.
Your choice.
Your choice.
That is precisely why one drives on ten years +/- Michelins over 95 percent of new tires. I have about as extreme of a
"test bed" as one can have.
Will have to search but believe I have posted on BITOG pictures of almost brand-new trailer tires failing in under 500 miles. I have been migrating all my trailer tires to Goodyear. People have great confidence in new tires, especially Asian tires....... I will take an aged Michelin Defender over a brand new Asian tire for extreme conditions such as summer towing under max load every day of the week.
I have a near new set of those Michelin tires on a like new set of GX 470 factory rims sitting in one of my trailers. Bought from a guy who pulled the near new Michelin defenders and factory rims for oversized Chinese tires and black Chinese rims.
It may be five to ten years before I get to using those Michelin tires, but despite what is commonly understood, Michelin defenders can easily last 15 years and more past date of manufacturing.
Michelin recommends not using after ten years. No reputable tire shop will install tires fifteen years after manufacture. Defenders are good tires, but they still deteriorate. Using ancient tires is dangerous.
Perhaps it is time for me to step in and comment on the subject of tire age.
First problem: Tire aging is highly dependent on temperature. Tires in - say - Phoenix - age much faster than tires in - say - Minneapolis. How does a government set a regulation with such a spread of conditions?
Second problem: The US Federal government can only set regulations for interstate commerce. That means they can only regulate trucks, airplanes, etc,, not passenger cars.
Third problem: The US Federal government can only regulate things where there is an issue. Is tire age such a large problem that the feds need to step in?
Fourth problem: What data do you base a regulation on? Where do you draw the line? Tire failures due to age isn't a bright line kind of thing!
What that means is the states are where passenger car tire regulations have to come from and there isn't clear data to set a regulation.
Clearly there is an upper limit, but what is it?
Here's what the USTMA (US Tire Manufacturers Association) says about it:
"USTMA is not aware of scientific or technical data that establishes or identifies a specific minimum or maximum service life for passenger and light truck tires. However, in some cases a tire or vehicle manufacturer may make a specific tire replacement recommendation regarding its products. If so, the consumer should consult the manufacturer with any questions with regard to following the recommendation. Furthermore, any such recommendation should not be considered a minimum service life for the tire.”
For more detail: Barry's Tire Tech: Tire Aging and Weather Cracking
So, a problem statement could be:
" Is a older tire from a world class manufacturer with a history of the very best R&D, engineering, manufacturing, quality control, manufacturing, testing, and quality control and better choice than a brand new Chinese tire that are now commonly sold across the US from chains such as Les Schwab and Wal Mart?
I am not sure that is relevant question. We know answer to that.
Running 15yrs old tire is what you implying is OK just because they are Michelin, when Michelin itself, you know, best in R&D etc. says not to do it under any circumstances.
And then there are specific climate conditions etc.
  • Like
Reactions: CKN
And nitrogen filling, and free tire rotations - been trying to rationalize changing my tires elsewhere, but never successfully.
The air we breathe is about 80% nitrogen. So, unless you're driving 200mph for NASCAR, that extra 20% doesn't do much for you. But if it's free...🤷‍♂️
Not only is it free, they now have a beautiful inflation station outside our local Costco tire center after they expanded it and moved the center to a separate building.
The sort of stations you see in Pennsylvania: Clean, clearly indicated, you preset your pressure and just press the button, as opposed to the usual NY & CT inflators at gas stations, which come with an invisible stick pressure gauge that you're supposed to read as it sticks further out of the housing, and requiring a million quarters for a time that's never enough to fill all four tires unless you prepare and take all caps off first.
I use a bike pump every 1-2 weeks and add a pound or two as needed. It's a good workout and easier than uncoiling the compressor hose.
My Skil inflator was $40 very well spent.
Keep in mind that these portable inflators do not have a filter/separator for moisture. The air that you’re putting into your tires will not be dry, so you’ll be subject to more temperature swings.
Went to church this morning. There is a old retired guy that drives between Alaska and Washington State twice every year. not surprised to see 2017 Michelins on his loaded and towing truck.
It's like well he's doing it...I might as well do it too! Has the camper weight and pulling a trailer.
It looks like he could be full time on the road-and not rolling in the bucks-so I will just leave it there. Otherwise I may not be as generous.
That's what happens when you one relies on Social Security alone.
I'll add just a caveat for NY. Sam's Club no longer offers road hazard in NY. Costco still does the 5 year road hazard.
Sam's Club in NY will honor the road hazard for tires bought in other states at Sam's Clubs that still include the road hazard.
2017 - that is 8 years old, if I can count. Not even sure when was the date of the install. You say that they will be good for next 7 years, ignoring the tread depth (like they sit in shadow or a bag).
Krzyś
Krzyś
That is why lawyers have a job.
