Originally Posted By: grease_monkey
Johnny and PT1 are right about the PCV Valve. let me tell you something... My 2000 dodge has a 4.7 V8 in it and that motor is supposedly a known sludge monster
This came up on a newsgroup I frequent recently. Where did you hear that the 4.7 is a "known sludge monster?" No one else in the NG had seen or heard of 4.7 sludge issues, apart from the fact that some models will form a water/oil emulsion in the top of the filler cap because its tall and tends to condense water vapor under the cap during short trips. It also turned out that a lot of people on the NG who piped up and said "yeah, I heard that too..." were simply confusing the 4.7 with the 2.7 60-degree v6, which did have Toyota-like sludge problems in its early incarnation.
You're dead right on the PCV valve clogging. For about 10 years now, manufacturers have been reducing the volume flow through the PCV system in order to get both better fuel efficiency and lower emissions, and a side-effect is that the lower air flow rate can accelerate clogging of the PCV system and can also aggravate sludge formation in the valve covers. With newer cars its more important to regularly service the PCV valve. Personally, I wouldn't let the PCV suck solvent through the engine, because that's where all the [censored] that breaks free will ALSO go- I'd remove the PCV valve and its tubing and flush it out manually, then re-install it.
