Originally Posted By: Doug Hillary
Hi,
there are many variations in the design of valve train components. Rollers are not always the best deal - they are great in certain applications (Series 60 Detroits (ceramic) for example) and buckets do work best in others like some Euro engines (some Porsche engine families)
Rollers can create traction problems with some lubricants (or vice versa) and whilst rollers are generally reliable they do have problems (like pin failures and etc)
It is a case of the engine designer having a Portfolio of possibilites and using the best one for the task - performance, durability, package size and cost/benefit being just some of the prime guidelines
Personally I see the wisdom in both
That is a different perspective on things, thank you Doug. I guess I had always figured that buckets were simply inferior, yet for something exotic as a Porsche... there has to be a reason!
Do you have any diagrams of how the Porsche setup is configured?
I am only familar with the general layout of a few of the Japanese styles and obviously that of Ford, which is roller. This is of course my reference point.....
I could see the advantage of a bucket setup being a lighter valvetrain.... Which means one could spec lighter springs. Though with the Ford Modular engines, it appears as though the roller setup has proven to be fantastic for durability....
And unlike setups from Honda, it requires zero maintenance.
Like running solid lifters, of both the roller and flat variety, I imagine there is a solid REASON for buckets to be used in a performance engine. I simply don't see the logic (other than cost) for them to be used on a "normal" car, where a hydraulic-lashed roller setup (like the one Ford uses) would eliminate having to open the valve cover.... pretty much ever.
In case you are unfamiliar with the Ford SOHC setup:
The rocker/bucket has a recess that fits over the top of the valve. In the middle there is a roller. Lash is taken up via a hydraulic lash adjuster which looks like a tiny lifter and is situated on the the opposite end and subsequently acts as the far mounting point. The cam sits on top of this setup and acts upon the rocker/bucket assembly via the roller.
It is pretty basic, and likely why it is very problem-free.
What has been your experience with rollers "skating" as you've mentioned?
Your knowledge always makes me curious
