I actually can’t get the tap started at all in either hole. Brand new tap from Helicoil. Won’t go in either.I have done less set up and did fine
Not a criticism- if the two imaginary cylinders are parallel within a reasonable amount you will be fine
If the hole is not perpendicular with the plane created with your set up something will give- the tap will follow the hole hopefully
It’s tapered.
