- Joined
- Sep 9, 2015
- Messages
- 1,072
I know the title is weird but after the morning I had it is rather funny.
Dad's WJ 4.0 had MIL light come on. His AC Delco thermostat was junk after only two years and the Jeep wasn't getting up to full operating temperature. Good father and son time.
We have Amazon prime so decided to order genuine MOPAR parts (thermostat and gasket).
Everything is smooth and easy as it should at disassembly. Putting it back was a little more difficult but we got it. Turn the Jeep on and coolant was leaking really badly. Hmmm maybe the gasket wasn't seated properly. Take everything back off, triple check mating surfaces we good to go, put everything back together ANNNNNNND leaking again!
Dad and I just assumed it was the gasket and pressed for time we just went to the local Federated Auto Parts store. Got a measly thermostat gasket for a whopping $1.07.
We get home and sure enough the MOPAR gasket ripped at the under side of the bottom bolt. We had a tough time trying to fiddle with the gasket and making sure it was properly lined up with the bolts etc etc.
We go to open this cheap thermostat gasket and behold! It ACTUALLY had a sticky adhesive like a sticker that mated to the housing! Absolutely brilliant and I wanted to give the guy/gal who thought of that a HUGE HIGH FIVE.
Assembly was then a breeze and we turn the Jeep on and no coolant leak.
Could not be happier. Best $1.07 I've spent.
Also check out this thermostat: (sorry if this picture is rotated, doing this from my phone)
I've never seen that bronze looking tab before. I can't describe it but playing with it, it goes in and out. Don't know if it's like a check valve or pressure relief thing. Any thoughts? Never seen a thermostat with that before.
