Originally Posted By: Master ACiD
the honda ohv isnt any more complicated than a briggs ohv, or a tecumseh ohv. is he talking about briggs flathead engines? yeah those are simple motors.
its the same argument that old shop owners make for the chevy 350 engine. you will never convence them anything but an american engine is better.
iffn you want a low performance flat head thats 1920's technology, gulps gas like its free and never really runs good or starts good then yeah buy a flathead.
but the rest of the world has moved onto better technology.
can you even buy flatheads anymore?
Isn't it the truth. If you want 50's technology buy a flat head Briggs. The only thing that's changed on them since that time is their begrudging addition of electronic ignition.
Briggs flatheads = hard to start, gas guzzling, oil sucking, 200 hour life (if you're lucky!) disposable engines.
To answer some of the other comments - Honda did make 3.5 and 5 HP flathead engines in the late 70's and early 80's. Yet they still had electronic ignition, pressurized lubrication, and long life. I had a 21" Honda mower with a 3.5 HP flathead engine and it used less than 1/2 the fuel of the Tecumseh engined mower it replaced while having substantially more power. Maybe Honda horses are bigger?
Whoever posted to stay away from aluminum cylinders is right. Even Honda has gone to building cheap aluminum cylinder models now. Obviously they see the disposable Briggs engines as some benchmark in short life/cheap and figure they too can build one and get away with it.
And as far as the people claiming the Briggs Vanguards are great and trying to use them to illustrate Briggs quality, give up. They are are good engines. But the only thing Briggs and Stratton on them are the nameplates. They're made in Japan by Mitsubishi or Daihatsu depending on cylinder configuration...
