Briggs 18 HP Startup Smoke
Madison, Wisconsin
I have an older twin cylinder L head engine. It always kicks off a puff of bluish smoke at startup, but it clears up after about 5 seconds. At the end of the year, I always do a oil/air filter/plug change and my plugs are usually black. I put about 10-15 hours per year on it.
I'm assuming I have oil getting by the piston rings. But I'm not seeing a oil spray when I look at the crankcase breather, and if I hold my hand in front of it, it stays clean. I'm running Mystik JT-8 Synthetic Blend 30wt.
Any suggestions on better oils that may reduce the fouling - or other thoughts? I've also heard that you should run the oil level a little low on these engines to reduce the smoke, but I've been a bit hesitant to do that.
I had a 25 HP Kohler that I used 500 Hours per year for 6 years and it always gave off a little puff of blue smoke at startup. Sold it with almost 3000 hrs on it and it still ran strong.
I wouldn't worry about it. Just check the oil level every once in a while and you will be fine.
Yep, vertical shaft engines do tend to get some oil seepage from the sump into the cylinders. Slightly overfull or parked off level will do it.
Joel
