Brand and amount to double the zinc amount from 800ppm to 1600ppm?
Hi guys..to double the zinc amount from 800ppm to 1600ppm which brand of zinc additive do you recommend and how much to use with 4.2 quarts of oil?thanks
If you have to add something to your oil, you're using the wrong oil. Oil formulas are carefully balanced. Don't upset that balance by playing backyard shadetree chemist with a supplement.
If you need additional ZDDP, there's plenty of oils out there that are already balanced around a higher concentration. Since application dictates chemistry, we also need to know what engine this oil is going in, the health of said engine, and how you plan to use it. Then we can give you some recommendations.
If they still have M1 racing 0w30 at Autozone for $2/qt that stuff is natively loaded. It comes out of the bottle looking brown thanks to the thicc add pack!
Exactly.
