When I was a mechanic anytime someone said the brake pedal went to the floor = installing a new master cylinder, whether needs one or not. Check for corroded/leaking brake lines/calipers/wheel cylinders. Make sure the new master cylinder is bench bleed, and the lines are properly bleed after installation.
Checking the brake booster is easy, pump the pedal and turn on the engine. The pedal should get firm, then release pressure with engine on.
