CARLOS DE LA CRUZ
- Joined
- Oct 20, 2023
- Messages
- 86
Hoping no with KIA, lol! ThanksI know of an issue with the second gen Ford Escapes where there was some type of issue, possible a software glitch that caused the brake pedal to drop to the floor randomly. Apparently there were multiple cases of this happening but the computer wouldn't record this error and there was no ABS light on. No TSB or update, so switching to a new ABS module could cause the same thing to happen. The problem was present on other Fords as well. Food for thought.
Thanks, I will keep an eye on this even I changed the MC, if not more issues, I will post it here to let you all know that is solved. RegardsWell, I cant tell you much from the pictures as I am not an expert in your particular vehicle. But the little black "seal piece" looks suspect.
An internal leak would not manifest outside of the system, therefore no fluid would be needed to top off.
"leak" in this case, would be also described as "recirculation of fluid where the fliud can go, but is not supposed to go when the pedal is pressed"
Some systems, like the one I had, had a valve that allowed fluid to flow freely when the pedal was released. This valve was allowing fluid past the main pusher, and accumulating.
In a hydraulic system, a little fluid movement in the wrong area is plenty to kill the pedal. Hydrostatic pressure build and is released much faster than air pressure and there is much less room for error.
