Originally Posted By: Char Baby
Originally Posted By: PandaBear
Originally Posted By: Grambo
Originally Posted By: NHGUY
They only lasted a year,I would be getting something different.
Which pads lasted only a year
What NHGUY said was why would OEM last you only 1 year? Your car is 2013 and it is only 2014 right now.
I guess the question is:
Why are you replacing the pads so early after only 1 year?
Are the pads truly shot?
Did you buy this 2013 Sonata in 2012?
Is there some caliper sticking?
CB
While my 2010 GLS has about 5-6mm left on the oem brake pads, with extremely heavy traffic in mind, these cars are known to have caliper piston/pin seizures when not properly serviced. The factory pin lube is complete garbage and so is the oem brake fluid. Simple basic brake maintenance with quality pin lube/brake fluid does wonders, and should extend the life of just about any pad/rotor combination
