You're correct.I recently did a brake job on a 13 year old chevy truck with akebono pads,this is what I found -
Break‑in behavior
Akebono pads do not require a formal bedding procedure. Their friction is fully cured at the factory, so they don’t need the “10 hard stops from 60 mph” routine.
Generic ceramics often:------
- Need bedding to burn off resins
- Smell or smoke during first use
- Leave uneven deposits if not bedded correctly
Akebono pads create a stable transfer film with normal driving. Generic ceramics often need aggressive bedding to stabilize the friction layer.
Bosch blue
Power stop Z17 are similar why so many believe they need to smoke the wheels off the car to mate pads and rotors on every application is beyond me. So many good pads and rotors become a failed brake job because of this old school thought process. There are other brands that also don't require a smoking hot bedding procedure especially if they're thermo scorched.
