I somehow had the inside pad on my right front wheel have a massive chunk of the friction material break off and catch in the caliper, and the pad backing gouged the rotor heavily. I checked the pads 6,000 miles ago and they had about 40% life left. That one kind of bends my mind as it's a failure I haven't seen or heard of before.
So I have to replace at least one rotor and I am doing front pads.
1. Besides the obvious pad set and rotor, I will take the other rotor in to get turned on the brake lathe. After this, do I need a shim plate to put behind the rotor to put it back in position? It's an OEM rotor with 90,000 miles that has been machined once before about 50,000 miles ago. Or should I just do both front rotors and sets of pads? Brake force is good, low noise is better.
2. Raybestos Advanced Technology, Professional Grade, Wagner ThermoQuiet or something NAPA reboxes? It's going to come down to whatever is in stock. As well, is there a major difference between the grey iron rotors if they aren't slotted and match the OEM "noise dampening iron." I can get a deal on the Raybestos.
3. What am I going to need for shims, lube, fasteners, cleaners, etc. to do this? I have the instructions for doing it somewhere but I am just wondering what other materials do I need?
Have at it guys...
Have at it guys...
