I have a post here a couple weeks ago, I have this metallic clicking-tapping noise when I press my brake pedal. It only happens once, it's not a repetetive click-click-click noise and I only hear it when braking at slow speeds, such as driving through my neighborhood or in a parking lot or when slowing down to stop at a red light. The noise happens as soon as I touch the brake pedal.
I read online last night other people have this same problem, and it is from the pads moving and shifting in the calipers because they don't fit tightly. Most people said new pads and/or rotors fixed it.
I am posting to see if anyone has had problems like this and see if anyone has found differences in the pyhsical construction and shape of their pads and backing plates themselves that causes or casused noise or other wierd problems. I am not talking about the pad material causing excessive dust or anything, I just want to see if anyone has had to change to a diffeent manufacturer because of odd noise problems like this one.
The pads on my truck now are Wearever Silver from AAP. They have about 12,000 miles on them now and I had no noise at all from them until 2 weeks ago. My truck brakes fine, stops with no pedal pulsation, chatter, brake fade or any other problems. Just this irritating click noise. Pads have plenty of meat left on them. I removed the pads and calipers 2 weeks ago, cleaned and re-greased the slide pins and slide surfaces on the steering knuckle and I put a nice coat of caliper grease on the back sides of the pads, and the noise went away for a couple of days then came back. It isn't any louder than it was when it first started but it is back and I want to fix it. Permanently.
I was thinking of trying a set of Duralast pads or maybe a set of the better Napa pads to see if it cures this noise. Any info is appreciated very much.
