With the system being sealed combines with the very high quality if material used in modern brake system, most manufacture's recommand not to change the fluid. They say that opening up the system will cause the moisture issues. Daimler Chrysler and Ford say to not change the fluids in their late model vehicles. If your system is properly sealed, no moisture will enter it regardless of where you live, it doesn't just seep in through the hoses. It is similar to freon on the A/C system, you don't flush it as maintenance because if you do not properly evacuate the system, you will only cauase harm. If you car/truck is MAX lines. If the fluid is low-below MIN, it's time for a brake job. DO NOT to add more fluid. It is is leaking, you have a totally differnet problem.
