Originally Posted By: Number_35
Typically I change the fluid when I buy the vehicle and then every two years after that.
It's cheap, and should keep the braking performance from degrading as well as extending the life of the master cylinder & slave cylinders/calipers.
As well, changing it regularly keeps the bleeders from rusting in place. If they are seized, I wonder if it helps to siphon some fluid out of the MC and refill with new fluid? Will the new fluid migrate down through the brake lines to the calipers? That is, if you did this regularly would you wind up renewing most of the fluid eventually?
Depends what you mean by eventually, but it'll be a long, long time because its a long, long way.
I'd think that dirt/dirty fluid will probably stay put, but there might be some diffusion and hence removal of water.
If I was in that situation I think I'd replace the rusted up component if I couldn't get it apart.
