The Gospel , mantra, and general rule for years is to always bleed the farthest wheel cyl first, then work your way back to the nearest to the master cyl.
But I can't see why, after much thought.
It doesn't make hydraulic sense.
OK. Let's say you bled your brakes farthest to nearest.
That means the next time you do it, your nearest was first bled! Or somewhere in the middle, depending.
If you have ABS, follow whatever the manual says - they can be fussy.
