Originally Posted By: MI_Roger
Originally Posted By: Gary Allan
Yeah. The "trick", if you can call it that, is to integrate the "free" energy sources to produce/facilitate the required energy needed. It doesn't really matter what the efficiency of the process is as long as you end up on the plus side of the equation in the consumption
roduction balance sheet. Well, that and the mass product output. Fossil fuels are deficit spending if viewed from that angle.
My local nuke plant should be heating our streets and houses during the winter instead of blowing trillions of btu's into the air while I'm buying heating oil or NG to heat my house. Steam intensive industries should be using this waste heat FREE for the cooling service that they provide to the plant.
Power plants used to do this. Many cities have central steam distribution systems for heating of buidings, primarily commercial, where the steam is a "waste" product from local power generating stations. Regretably, these old small power stations are being forced out of use, and being replaced by massive installations located in remote areas where no use of the waste heat is possible.
Our municipal coal-fired power plant sells their waste steam to the big ethanol plant located just beside them. It's a convenient arrangement made possible only by their close proximity.
